Im looking for a good effects processor, my Denon mixer does not have any built in and I know VDJ has a few downloadable ones.
Is it worth the 800 US Dollars for this FX Processor, or does anyone know of others as good or less expensive, is it worth is at all??
Cheers.....:)
http://www.pioneer.co.uk/uk/product_detail.jsp?product_id=11063&taxonomy_id=44-107
Cheers.....:)
geposted Wed 04 Oct 06 @ 7:23 pm
You can do many thigs with VDJ effects. Pioneer effector is really great. You can also look at kaos pad or other effectors. But again.. you can do almost everything with VDJ effects and one external controller for them.
geposted Wed 04 Oct 06 @ 7:29 pm
Thanks......I did not realize there was an external controlller available for the VDJ effects.
Can I get a little more information on that piece of hardware?....thanks again!
geposted Wed 04 Oct 06 @ 7:40 pm
You can use almost every midi hardware to controll VDJ effects. It seems to be the best choice M-Audio x-session. It is external USB interface to control any function in VDJ. Some users have it. great thing ;)
geposted Thu 05 Oct 06 @ 2:08 pm
Dude i'll be frank with you. Get the EFX 1000's, if your after an effects machine of high quality, vitual dj just wont cut it compared to the high end effectors, unless money is an issue, im just assuming its not
geposted Sun 08 Oct 06 @ 12:11 pm
Get the Pioneer EFX 500 (less money) because you are not going to use the extra effects from 1000
geposted Tue 10 Oct 06 @ 12:20 pm
