Hi there. I've just bought VDJ4 and I have the Hercules MKII too. When I try to setup the TCCD the signals window shows a lousy noise when not playing the TC (That ,if I choose the hercules for Driver). If I choose Asio4All as a driver it says " Not enough channels ". If I manage to configure it with no problems , when I play the TCCD , I can see the waveform on the signal window but when I press "Auto-Config" it says "No timecode signal found"
I use 2 Pioneer CDJ-800 and an old Gemini Mixer. I have downloaded the vdj_timecode.mp3 and I have
used Cool Edit to decrease the volume cos' it was too loud for the program. What more can I do? Is there anyone with the same problem? Thanks in advance.
geposted Thu 05 Oct 06 @ 9:59 am
I also use powered hub for the Hercules & a power adapter for it
geposted Thu 05 Oct 06 @ 2:37 pm
