hi all, i had to reinstall vdj 3.4 for my dj console mk2. now when i play a track it sounds fine then when i turn the equaliser nobs for higher settings, it makes the music sound like the volume is being turned down slightly then back again quite rapidly.it will continue to do this throughout the length of the song.the only way i can stop it is to reset the equaliser settings. before i had to reinstall vdj 3.4 it was working fine.is there something i can do to fix this? thanks
geposted Thu 05 Oct 06 @ 11:47 pm
It sounds like "Limiter" option in VDJ is on, disable it.
geposted Fri 06 Oct 06 @ 7:09 pm
sounds like it :)
geposted Sun 08 Oct 06 @ 10:03 pm
