when I open a playlist, VDJ (V.4) autoloads 2 songs for play. Is there a way to stop this from happening? I want to pick the songs to load. thanks
geposted Sun 08 Oct 06 @ 4:13 pm
Well it's a couple step process - no configuration settings to stop it --
Step 1. Select your playlist from the left (folder) panel, this should populate the center (file) panel
Step 2. Your choice -
a. Click on a file then use Ctrl+A to select all and drag the entire list to the right (playlist) panel
b. From the center panel, hand pick the songs and their order and move them individually to the playlist panel
From here you can pick and choose the songs that get loaded first.
cstoll
cstoll
geposted Sun 08 Oct 06 @ 5:16 pm
Thanks, I'll try that
geposted Sun 08 Oct 06 @ 5:48 pm
That was the ticket! Works great
geposted Sun 08 Oct 06 @ 6:54 pm
