Just wondering. I am having issues with my left play button on my DAC-3 not always responding. I have to hit it a couple of times sometimes. Of course the play button, go figure... :( Is there a way to fix it? Anyone ever have a sticky buttons on this unit and was able to fix them? Right side works fine.
geposted Tue 10 Oct 06 @ 2:47 pm
There are already a couple of threads on the forum if you do a search that will give you an indepth answer to your problem. I think the consensus was that the sticking could be relieved by dismantling, cleaning and use of some of that special lubricating spray, but if you do a search you'll have plenty of information.
a
a
geposted Tue 10 Oct 06 @ 3:15 pm
