I got a problem with my time coded vinyls ive plug my turntable to my input soundblaster and my mixer to output...when i play the vinyl they say cannot detect vinyls...ive installed the drivers aiso and all that but it doesnt work ....why?? please help....
geposted Wed 11 Oct 06 @ 1:35 am
did you get the vinyls from this site?
geposted Wed 11 Oct 06 @ 1:55 am
Yes ive bought it from this site
geposted Wed 11 Oct 06 @ 2:30 am
whats your VDj version? also it would help to modify your profile so that ur timecode icon would show up, that way we know you have the good TCV's
did you enable the line in's through the soundcards software?
geposted Wed 11 Oct 06 @ 2:55 am
HI,
I'm using a Sound Blaster X-FI Extreme. Previously I was using a PCI soundblaster with ASIO for all driver, sometime I was not having the TCV signal even if I was sure that everything was ok. The only thing I found is that if I was opening Creative Recorder selecting the line in and clicking on the monitor option of the recorder then it was working ok. Why, I'm not sure it looks like even if the setting of my soundcard was ok volume etc, it was not working unless the recorder activated the monitor. Is it a SB bug? I don't know, but you can try it just in case it solve your problem.
Thanks
Thanks
geposted Wed 11 Oct 06 @ 3:09 am
enable automatically theres no option for disabled...ive got vdj3.4 pro cuz i like this version better
geposted Wed 11 Oct 06 @ 3:12 am
that could be the problem , the 3.4 demo only allows one timecode for only 5 minutes
geposted Wed 11 Oct 06 @ 3:15 am
but i have the full version and its not even working
geposted Wed 11 Oct 06 @ 3:22 am
I dunnot have the Creative Recorder ...why..
geposted Wed 11 Oct 06 @ 3:27 am
If you have the full version please enter your serial in your profile, otherwise there is no support available for 3.4 unofficial version
as we have no clue what has been done to it
geposted Wed 11 Oct 06 @ 3:28 am
Is the x-fi extreme works with the tcv's?
geposted Wed 11 Oct 06 @ 3:48 am
Nothing will work correctly unless u have a legal 3.4 or above version
Crack versions of 3.4 tend to have many bugs
geposted Wed 11 Oct 06 @ 3:54 am
