i ve downloaded demo vdj4.1 but when i try to open it its says sound driver asio problem
and bcd dont work buy bcd work fine with original bdj software
please help me i really want to test new vdj4.1 thanks
geposted Wed 11 Oct 06 @ 3:27 am
Make sure you set the latency to Auto in the performance tab and it should work. As soon as you use any other setting it give that error message on my system
geposted Wed 11 Oct 06 @ 11:18 am
hi there auto works but only for 5 10 sec and it stop what is the best settings for keep it going
geposted Wed 11 Oct 06 @ 1:03 pm
Please give me some details of your system. Are you running the latest bcd drivers
geposted Wed 11 Oct 06 @ 1:18 pm
in the same performance-tab. deselect 'overclock'
it should work that way.
geposted Wed 11 Oct 06 @ 3:19 pm
geposted Wed 11 Oct 06 @ 5:36 pm
The demo is 4.0, I think.
geposted Wed 11 Oct 06 @ 5:48 pm
Demo of 4.1 is available already
geposted Wed 11 Oct 06 @ 6:19 pm
Thanks Philly, didn't know that ;)
geposted Wed 11 Oct 06 @ 6:45 pm
I still cannot get it to work for more than thirty seconds using WDM or ASIO :(
geposted Wed 11 Oct 06 @ 7:04 pm
this is because buffer runs out (Behringer drivers dont like that)
Check if your USB port share IRQ's with intensive devices such as LAN, WiFI, graphic cards etc.
Disable those you can, if IRQ is shared.
Or try different USB port.
geposted Wed 11 Oct 06 @ 7:39 pm
i had the same problem with my bcd2000. it helped me by unchecking 'overclock' in the performance tab. did you guys try that? it's like talking to a wall... did it help or not? try it!
geposted Thu 12 Oct 06 @ 6:40 am
