I am wondering if I am doing something wrong, because when I use effects that have tails (are supposed to continue getting softer) like delay or reverb, the effects stop when I stop the record. Is there a way to make the delay trail after I stop the record (like it would using an external effects processor)? This is the way it should be, most hip hop djs beat match two songs for example, begin mixing the second one in and stop the first with a beat-matched delay (typical of djs who use cd players). If there is a way to do this in VDJ I would like to know.
I am using v 4.0, and I read in the description of 4.1 that they have redone the effect engine. Could they have solved this issue? Ii havnt installed the newest version yet, but I hope that either I am missing something or its been fixed in the new version.
Any comments would be appreciated.
geposted Wed 11 Oct 06 @ 11:36 am
Don't know much about it, but pressing stop stops all processing on the deck, including effects. Tryed pause?
geposted Wed 11 Oct 06 @ 1:13 pm
Sadly, all the effects in VDj (VSTs also) behave the way you describe (pause doesn't help, of course) with all the versions up to date (including 4.1). I asked long time ago to have an option of "active" effects that work as in music production sequencers (i.e. Cubase, Reason etc.), where they process the signal independantly of the "timecode" (not reffering to TCV).
My guess is that this way (in VDj) effects are working too inefficiently and probably take up more resources than actually would, and in most cases produce unwanted results when the deck is played in reverse, scratched etc. It was probably also the cause of many crashes with early versions when using these plug-ins.
I really hope to see the "normal" effect host implemented in VDj in the future, but had not seen no (public) conformation yet that it is either being worked on or considered.
e
e
geposted Wed 11 Oct 06 @ 3:35 pm
thanks
geposted Fri 13 Oct 06 @ 8:02 pm
I agree with erxon. This way I can also "merge" standalone Microphone FXs made with BASS.DLL, and add "standalone" effects, like in standalone hardware (FX devices or mixers for example).
geposted Fri 13 Oct 06 @ 8:10 pm
i like the virtual dj
geposted Mon 06 Nov 06 @ 3:50 am
glad to hear it hope to see you as a pro user soon :)
geposted Mon 06 Nov 06 @ 11:00 am
