Is there supposed to be a short delay when stopping and starting a tune using the jog wheels? If not how do i set this up corredlty...or is this a function they are not designed for? My fear is am i gonna run into the same sorta problem once i upgrade to the TCV option. I find the software very reactive using the mouse and such.
In general I VERY happy with the MK2 and this is my major hang up with tit. ALso is there a way to disable the jog wheel to stop those annoying accidental bumps?
thanks all
redcoat!
thanks all
redcoat!
geposted Fri 13 Oct 06 @ 4:55 pm
You can do almost anything with MK2 maper. And try to install lastest drivers or run it through powered usb hub.
to download maper you need PRO version.
geposted Fri 13 Oct 06 @ 8:53 pm
