sonique is for registered users which I'm not yet,strobe(s) and the others don't work.The slideshow will briefly display an image when you click activate,but will not change to and display additional images.
another question, after a track is played it is flagged and then moved to ......that days most recent history folder?? Is that correct? those are under playlists.
geposted Sat 14 Oct 06 @ 4:41 pm
if you want sonique effects change activate the slide show, check at the picture below:
geposted Sat 14 Oct 06 @ 4:52 pm
that's a nice pic.it's no help, but nice pic.
the sonique isn't going to work unless I buy.on never appears inside the blue box and the folders inside sonique are empty.
what I don't understand is why a slideshow of my own .BMP won't work?
the strobes and all the others aren't working; are they disabled in the trialware?
I read all of the pages in the manual concerning videos and fx, so far did not find anything about the visualisations.
geposted Sat 14 Oct 06 @ 5:31 pm
ladies?,germs, pets and appliances,"this is how we do it"
config/video tab/use this plug in for audio only files/(choose your plug in).
i chose slideshow, it already had the path to the folder, and it works.
next, how to get the popup window to remain at fullscreen......
geposted Sat 14 Oct 06 @ 5:40 pm
yes, windows minimizes automatically I guess that's a bug, but hopelly will be fixed in the next version.
geposted Sat 14 Oct 06 @ 5:49 pm
thanks,where is the popup hiding when it hides?
what makes it popup? keep it clean
geposted Sat 14 Oct 06 @ 6:21 pm
manquin your cpu useage looks high in that pic. i notice the cpu monitor in VDJ much better than traktor's, I actually check task mgr or a utility called process explorer to check the "knight rider" screen......instead of traktor.
geposted Sat 14 Oct 06 @ 6:27 pm
clicking fullscreen makes it popup.
geposted Sat 14 Oct 06 @ 6:46 pm
sonique effects require a lot of cpu usage, I had several programs open when I print the screenshot.
geposted Sun 15 Oct 06 @ 7:10 pm
