I'm using the MK2 with 2 different computers and it worked fine so far.
Firmware v1.3.12.6, Driver v3.2.0.0, DJ API v1.3.5.0, CPL v1.2.0.8 (latest package from Hercules.com)
Now I have downloaded the 4.1 Trial VDJ and the following problems occur:
1st scenario: driver of console is installed and I install VDJ 4.1 afterwards
when I start VDJ, an error message appears stating that there is an ASIO driver problem.
Music I put on players won't play. This continues to be the case no matter what soundcard (even the MK2 option) I choose in the options.
2nd scenario: VDJ 4.1 is installed and I install the console afterwards
when I start VDJ, an error message appears stating there is a directX problem (9.0c installed).
Music will play, the console works, but I can't get the headphones to work on either channel. Only on the "MIX" and "SPLIT" setting I hear both of them but of course only when the fader actually plays both of them anyways... basically I can't pre-listen. This also happens whatever soundcard I choose in the options.
Any suggestions? Please mail to KadeDLK@aol.com
geposted Sun 15 Oct 06 @ 7:09 pm
i get that 2 :(
and time code has gone all funkey
i have heard this is being looked at in 4.2 is that true ?
geposted Mon 16 Oct 06 @ 11:25 am
for the TCV + mk2, here is the current solution:
set the latency to "auto" in v4.x
geposted Tue 17 Oct 06 @ 1:59 pm
Thanks im gona try the new patch tonite and see what happens :)
geposted Tue 17 Oct 06 @ 3:57 pm
And the first problem is solved with v4.1 rc2.
Topic now closed
Topic now closed
geposted Tue 17 Oct 06 @ 8:37 pm
