ok so i had problems wit my tcv again just am in ago when i was working on them. The problem was that my right deck was screwing up having severly low latency and skipping i thought maybe my tcv was scratched so i switched the tcvs and it did the same thing it would go and skip. I know it's not the deck it self because i tried a regular vinyl on it and nothing bad happened.
geposted Sun 15 Oct 06 @ 10:44 pm
Have you tried swapping over the headshells on your decks to rule out needles.
Are tracking weights OK?
geposted Tue 17 Oct 06 @ 3:10 pm
do you have RIAA pre amp checked? for newer tcv turn it off, and try turing up the gaiin in the options a little
geposted Wed 18 Oct 06 @ 2:27 am
