Goodday, I Just wanted to find out if I can map controls to a midi controller in the demo version. I just built a joystick circuit which works fine but gettin to the remote tab in VDJ and checking "ebnable", I cant seem to find anywhere to assign the controls from...
litaninja
litaninja
geposted Mon 16 Oct 06 @ 2:00 am
Under the "enabled" checkbox, there is a CONFIG button, which opens a list of shortcuts that you can set up. It's usually empty by default, so start with a top right button "Add...", choose a function from the list and push the midi button to detect it.
e
e
geposted Mon 16 Oct 06 @ 8:36 am
