Hey Cyder:
Was just checking your pics. Congrats on the wedding and baby.
I downloaded your video skin and you really look like you worked hard on it- it is amazing.
I have a simple question.
What short cut key would I make so that when I hit the keyboard the video transition will change?
I played around and I saw the short cut that lights the video transtion (gets it ready to activate) but it won't change on its own.
I even put my mouse over the little nob which is the transtion, and it said 'T" which is what I assigned, but when I hit T it doesn't transition.
I am looking for this feature which is the equvalent of hitting the little preview screen in the default skin with 4.0
make sense?
thanks.
B
make sense?
thanks.
B
geposted Mon 16 Oct 06 @ 5:16 am
OK Cyder,
I am getting closer,
now when I hit the "T" which I set up as the transition kry, it transitions only a little bit and not fully. The little knob goes up a little and then stops. In other words it does not fully transition.
Also it only happens one way. The "slight transtion" isn't happening on both decks.
I'll keep trying.
B
I'll keep trying.
B
geposted Mon 16 Oct 06 @ 5:23 am
I figured it out.
Sorry-
no need to reply.
thanks.
Sorry-
no need to reply.
thanks.
geposted Mon 16 Oct 06 @ 5:31 am
I'll be adding that in the next version of vmix :) The problem is i can assign it to the pannels correctly it will probably get its on button in the center.
geposted Mon 16 Oct 06 @ 4:34 pm
