how do i get vdj xp style on 3.4 after having 4.0 installed
geposted Tue 17 Oct 06 @ 12:15 am
There is a skin for it, look in skins section.
geposted Tue 17 Oct 06 @ 11:58 am
I don't know, but is that so important to you ? ....
Even my win xp have not "xp style" ...well they look like windows95...
For optimizing and creativity reasons..
geposted Tue 17 Oct 06 @ 12:58 pm
Lol mine too, so the windows looks ugly but I am looking at the VDJ all the time anyway and that way my PC is much faster.
geposted Tue 17 Oct 06 @ 6:53 pm
Here Arnold, don't let this guys bother you. :) https://virtualdj.com/addons/download.html?addon_id=1593
geposted Tue 17 Oct 06 @ 7:10 pm
lol ..
geposted Tue 17 Oct 06 @ 7:19 pm
It's the same file for all the version of VirtualDJ
geposted Tue 17 Oct 06 @ 8:41 pm
the file doesnt get into 3.4 no matter what ive tried how do i do it
geposted Thu 19 Oct 06 @ 4:56 am
i have 4.1 and when i try to install on my system, it dosent go to my skins folder...
where does it go??
can someone tell us where it installs to, so i can move it to the correct skins folder
thanks
where does it go??
thanks
geposted Thu 19 Oct 06 @ 1:38 pm
It is installed in the same folder as virtualdj.exe
geposted Thu 19 Oct 06 @ 6:11 pm
er...
nope!
ive clicked several times on installing this skin and it dosent appear in (virtualdj directory)skins
ive done a search to list of all files within my virtual dj directory, and nothing new gets created there. no zip files, nothing.
ps. should this topic be in skins forum?
nope!
geposted Thu 19 Oct 06 @ 6:20 pm
Please listen to me one second: the plugin XP Style is NOT A SKIN but a special file which improves the config of VirtualDJ for exemple
geposted Thu 19 Oct 06 @ 6:23 pm
you also have to enable "use visual styles on windows and buttons"
right click my computer and go to properties
click on the advanced tab under performance select settings, scroll all the way down till you see "use visual styles on windows and buttons" and just make sure that its on
geposted Thu 19 Oct 06 @ 6:33 pm
oh, right then..
i never noticed.
i have Royale Theme on my system and it makes the menus look 100% better!
thankyou, all
i never noticed.
thankyou, all
geposted Thu 19 Oct 06 @ 8:50 pm
