Poor scratching sounds. I just installed the new Hercules DJC Mapper v4.1 and the quality when you scratch the jog weel is very poor. What can I do? If I don't install the mapper my loop buttons do not work propperly. Can anyone help?
geposted Tue 17 Oct 06 @ 7:40 am
look at the productivity tab on the main config and try changing stratch to quality ,
not reactivty ?
not reactivty ?
geposted Tue 17 Oct 06 @ 11:28 am
Anyways I never liked scratch quality, not because the sound engine, but for the small dials on the console... vynils or cds with a big decent wheel, that rocks !
geposted Tue 17 Oct 06 @ 12:52 pm
It works just fine without the Hercules DJC Mapper v4.1, However when 4.1 is installed the loop, fx do not work properly. Can someone assist? I onley see this when the new mapper is installed.
geposted Tue 17 Oct 06 @ 9:24 pm
Move the slider "rotary speed" in the mapper
geposted Tue 17 Oct 06 @ 9:45 pm
