Just installed the newest version of VDJ, 4.1r2. I have used v 3.x where a single push on the SYNCH-button will play the loaded song automaticly. How can I enable this in the new version?
Question 2.
I have DXM01 mixer from Numark with 2 USB channels (It works just like 2 sound cards). When I listen to my recorded set, all the tunes that I have played in my headphones are recorded as well. How to prevent this?
Hope you can help!
Cheers
Fredrik
Question 2.
Hope you can help!
Cheers
Fredrik
geposted Wed 18 Oct 06 @ 1:01 am
Please enter your serial so we can see that you have a pro license.
geposted Wed 18 Oct 06 @ 9:24 am
tsk tsk tsk
yes add your serial please mmm
as its actualy impossible to get these updates legaly with out having it added to your page
geposted Wed 18 Oct 06 @ 12:58 pm
aparently not my bad
u can now get the 4.1R2 demo
try changing making a keyboard shortcut :)
ul find shortcuts in the config settings
geposted Wed 18 Oct 06 @ 1:23 pm
Hehe, yes, I have the 20 days trial version.
So I can only do this using a keyboard shortcut?
geposted Wed 18 Oct 06 @ 1:28 pm
u could change the xml file of the skin you are using , not sure how that would work exactly tho
does any one have any ideas?
geposted Wed 18 Oct 06 @ 4:45 pm
I do :))
Press Sync with right click on mouse, it is the old behaviour of sync button.
geposted Fri 20 Oct 06 @ 12:43 am
If you modify the xml the command would be "sync_nocbg" instead of "sync".
geposted Fri 20 Oct 06 @ 1:54 am
nice one :)
geposted Fri 20 Oct 06 @ 3:48 pm
Thanks a lot:)
Now I'll order the full version!
geposted Fri 20 Oct 06 @ 3:51 pm
Go get it djfreeloop ;)
Hope to see ya soon as a part of VDJ world :)
geposted Sun 22 Oct 06 @ 7:10 am
