i have 3.0, how do i get it to play wma files! i have the music stored in a file. and it seems to all be wma files, thanks
geposted Wed 18 Oct 06 @ 10:48 am
3.0 is rather outmoded these days - even when I bought mine, I think it was Version 3.3 or something.
I think Version 3.3 upwards can play WMA files - all my files are WMA - smaller than MP3 - though the Database Updater I downloaded from here can't do WMAs at the mo.
Should be able to handle anything, really.
WAV files are quite big - you'd get about a dozen CDs in there and then the computer would try to convince you that the drive is full!
geposted Wed 18 Oct 06 @ 11:07 am
If you purchase the program, you can upgrade and play them without any problems
geposted Wed 18 Oct 06 @ 10:36 pm
Does it even play the protected ones?
geposted Wed 18 Oct 06 @ 10:54 pm
Yes VirtualDj Plays DRM WMA, but only the Updated Versions 3.4 and Above
and you have to have the License
geposted Wed 18 Oct 06 @ 10:58 pm
so hows about you enter the serial number in your profile then eh??
geposted Fri 20 Oct 06 @ 7:52 am
