4.1r2 seems to stop playing mid-song for no reason. VDJ does not completely freeze, but you cannot restart the song, or load another song. I have installed 4.1, but I am having the same issue. Sometimes is will run fine for 30 mins or more before running into the issue, other times during the 1st song.
I am running the BCD2000 configuration as specified in the forum, with latency set to 'auto', 'overclock' is OFF and so is 'Safe Mode' under "Performance". Preset is set to 'Fastest'.
I am using a Dell Latitude D600 1.6mhz with 768mb of RAM and over 15gb available HD space. So I do not believe that this is a hardwarde/resource constraint issue.
Idea's?
- Paul
Idea's?
- Paul
geposted Wed 18 Oct 06 @ 9:48 pm
Try setting a higher latency in the BDJ console, Also might be due to lan or wireless card since Behringer recommends disabling these devices. Could also be due to devices sharing the same IRQ as BCD
geposted Thu 19 Oct 06 @ 5:09 pm
Looks like it was the wireless card. Probably sharing an IRQ setting with the ASIO driver. Anyhow, working sweet as can be now.
Thanks for the advice!
- Paul
- Paul
geposted Sat 21 Oct 06 @ 7:08 am
I got an idea for you....why doy dont pick ASIO drivers inteast BCD on sound card settings? this will make it work I use the bcd with TCv in asio mode and everything runs great, just pick ASIO drivers do not pick BCD as a sound card and everithing will run ok
Regards
Dj Quintana
Regards
Dj Quintana
geposted Mon 23 Oct 06 @ 9:02 pm
Ok!
I have tried every blog every idea and still no success! I am trying this on 3 different laptops(two different models) and have 0 success making it work. I am not using TC of any sort. I can get beautiful sound until I try to do ANYTHING else and then either(depending on the settings) the sound either cuts off completely or gets very distorted.
Juliocqb,
I have duplicated your blog with no better results than any other.
I have (2) AMD1.2 ghz laptops with 512 ram and (1) P4 2.8 ghz 512 ram and get the exact same results on both no matter what settings I choose I fail. When running in ASIO mode, I can only run for about 30 seconds before freeze. When running in BCDJ Mode I get sound degredation the longer it plays, the worse it gets.
Oh yeah, I have disabled all wireless networking in Hardware area. Should I also disable regular network and modem?
Just looking for any answers that might help.
Thanks
Juliocqb,
Thanks
geposted Tue 24 Oct 06 @ 8:36 am
Partyman wrote :
Ok!
Juliocqb,
Thanks
Juliocqb,
Thanks
add me to your msn.
regards
dj quintana
geposted Tue 24 Oct 06 @ 3:35 pm
Gladly, what is your MSN info?
geposted Tue 24 Oct 06 @ 6:02 pm
you coul find it at my blog, jusc clip on and you' ll get it
geposted Tue 24 Oct 06 @ 6:12 pm
Same problem here!
I have a IBM thinkpad P4 2.4 with 1 Gig RAM, disabled everything and anything! Followed ALL tutorials and tips to the T! Still, after about 20min or so it just STOPS.
Please someone.... I'm starting at a new place next week and I'd love to use the BCD2000 instead of the hercules djconsole that I originally used. BTW, would the console work with VDJ 4.1r2 or do I have to install 3.4?
Please, please, please...HELP!
geposted Sat 04 Nov 06 @ 2:32 am
It works with version 4x but some laptops have problems with drivers so is better to use a desktop.
geposted Sat 04 Nov 06 @ 3:58 am
mmm... hard to carry desktop for gigs four days a week... i have same problem with Sony VAIO
geposted Mon 06 Nov 06 @ 10:03 am
There are special gabinets for carry if you are mobil dj, they can be atached easily on a rack.
geposted Tue 07 Nov 06 @ 1:25 am
i know them but its not practical going on a scooter LOL. and remember that desktop needs also monitor.
geposted Wed 08 Nov 06 @ 8:24 am
yes, lcd is pefect for me.
geposted Thu 09 Nov 06 @ 1:36 am
djWhitie wrote :
Same problem here!
dj Wihitie, I've a T30 Thinkpad with 1.8Ghz p4, 1 Gig Ram. It's works fine with BCD & vdj 4.1r2. Two weeks ago I performed a 2 hours live set without any problem. I use the configuration recommended here. Do you have the last BCD driver? (to be downloaded from Berhinger site)
geposted Thu 09 Nov 06 @ 4:25 pm
THERE IS ONLY ONE SOLUTION TO ALL THE MUSIC STOPPING.
TURN OFF YOUR WiFi CONNECTION!
YOU CAN TURN IT OFF USING THE KEYBOARD USUALLY THE "FUNCTION" BUTTON PLUS ANOTHER ONE. IN SOME TOSHIBA LAPTOPS, THEY'RE IN FRONT OR AT THE SIDE OF YOUR LAPTOP.
JUST REFER TO YOUR MANUAL.
ANOTHER IMPORTANT THING,
DISABLE YOUR WIRELESS NETWORK CONNECTIONS UNDER CONTROL PANEL->NETWORK CONNECTIONS.
MAKE SURE IT'S DISABLED.
NOW YOU CAN FOLLOW julio's INSTRUCTIONS IN HIS BLOG.
geposted Fri 10 Nov 06 @ 4:55 pm
Let me know if my advice worked.
geposted Fri 10 Nov 06 @ 10:46 pm
hi, i have the same problem, but i found out that if you move the latency setting to another value, apply the change, and then go back to auto and apply it runs again from the point it was freezed so, any new idea? ive done every tip on the blogs, let me know if you guys find something, the other thing i,ve noticed its that it can happen any time once after 30 minutes, another can happen after an hour etc.. its not a specific timing for thee freeze
raul
raul
geposted Wed 27 Dec 06 @ 7:33 pm
geposted Wed 27 Dec 06 @ 8:45 pm
Yes I have the same problem I have tried all the fixes suggested & still have problems. It is definately a ASIO problem as I have found with the new verion 4.2 If you go into config & change the settings once it has locked (ie click on safe mode) then the software will start working again. No need to shut down to get it working again now Any further suggestions ?
geposted Tue 09 Jan 07 @ 2:55 pm
