Yesterday, surfing in internet i found:
http://www.mixvibes.com/new/pageeng/page.php?x=mv6vinyl
They appear
Brand new Time code CD:
# First specific CD decks time code, especially developped for CD players
# 5ms jump detection time
# 1st track: 24" track
# 2sd track: Track Selection to load from your CD songs from the MixVibes playlist
# Compatible with all CD decks
And
V2B Colored Vinyl
(Orange, White & Transparent)l
# New time code
# 1 minute splits
# A side: 12" with an endless track for long Mixinfinite track
# B side: 11" + 1" Track Selection to load from your vinyl songs from the MixVibes playlist
# the new update allows the Master Tempo control through your turntable pitch!
# Weight: 124 g
# Orange, White & Transparent In Color
# Limited Edition
Seem to be second generation tccd and tcv.
1- Is VirtualDj compatible with this new timecode ?
2 - If not. are there any plans to support them in a near future ?
3 - Are there better than VirtualDj Timecode CD and vinyls ? Is it worth to buy the cd and vinyls in mixvibes as price is very similar and seems to be more advanced ? May i have compatibility problems with these cd and vinyls in virtualdj ?
http://www.mixvibes.com/new/pageeng/page.php?x=webshop
Thanks in advanced
They appear
And
V2B Colored Vinyl
# New time code
# 1 minute splits
# Weight: 124 g
# Limited Edition
Thanks in advanced
geposted Thu 19 Oct 06 @ 8:21 am
You are referring to another product.
VDJ is only compatible with its own TCV's. Ok SSL tcv's work also, but there is a limitation in needledrop. So if you would like VDJ and would like to use it with timecode, you will need to purchase the VDJ tcv's.
Ewout
Ewout
geposted Thu 19 Oct 06 @ 10:16 pm
So we can say that virtual dj is using a first generation of tcv and tccd and mixvibes is using a second generation of tccd and tcv ?
So is there any plan to pass or to update to second generation tccd for virtualdj ?
Thanks in advance
Thanks in advance
geposted Thu 19 Oct 06 @ 10:48 pm
