why when i install virtual dj in my pc i´t stays very slow?? is there anything that i can do to fix it because when i use atomix mp3 stays perfect?!?!
thanks!! by the way my pc is: Pentium III,868 MHz,240 MB and 80gb on my HD
geposted Sat 21 Oct 06 @ 7:27 pm
You have the minimum specs, so unfortuneatly it's probably as fast as it will be
The highest a socket 370 can go to is a 1.2 p3 or a 1.4 celeron, (if it supports it) so as a suggestion try to get a P4 system
geposted Sun 22 Oct 06 @ 2:44 am
Is this the demo, or full version?
geposted Sun 22 Oct 06 @ 11:41 am
Check the video settings. If it is on activate, the MP3's will load slow. When I do karaoke I have to deactivate the video in order for the mp3's to load normally.
geposted Sun 22 Oct 06 @ 7:35 pm
