Cs
try unziping the files and letting them both sit in the skins folder then lanuch vdj see if the error happens.
I just tried it again on my pc and its working for me.
geposted Sun 29 Oct 06 @ 4:35 am
Extracted works fine. Re compressed to zip and same error.
cstoll
cstoll
geposted Sun 29 Oct 06 @ 7:01 am
I was afraid of that, It seems vmix has reached the grapical limit of windows zip. I'll correct it in the next version.
geposted Sun 29 Oct 06 @ 3:33 pm
Cool
geposted Sun 29 Oct 06 @ 5:34 pm
just so everyone knows you can't have a bitmap larger then 15,000 pixels and larger then 48mb
geposted Sun 29 Oct 06 @ 7:24 pm
Ok updated, no system should get an xml error anymore.
geposted Sun 29 Oct 06 @ 8:17 pm
Excellent! Works!
geposted Sun 29 Oct 06 @ 11:52 pm
Were can I download this skin ?
geposted Mon 30 Oct 06 @ 10:55 am
geposted Mon 30 Oct 06 @ 11:49 am
HI,
I was getting that error also.
If I d/L VMIX again (MOnday 10-30-06) your update should fzx that? Do I have to delete anything or just download it into the VDJ folder and it will replace the other versions of VMIX?
TX
TX
geposted Mon 30 Oct 06 @ 5:14 pm
The installer should overwrite the older version.
geposted Mon 30 Oct 06 @ 9:12 pm
It did.
Amazing work.
I like the split waves so much better than the waves being overlapped.
You are talented.
And I like that you take requests (like the title thing you changed- much better now, no scroll!)
you r the man.
B
Amazing work.
You are talented.
you r the man.
B
geposted Tue 31 Oct 06 @ 4:40 pm
Hi Everybody!
DJ Cyder, I want to know if it's fixed the SYNC function on the panels of the skin.
The Sync function is one that most i use
Realy i love this skin!
Cherss!
Dj Pillo
Cherss!
Dj Pillo
geposted Fri 24 Nov 06 @ 11:57 pm
sync works now by clicking on the the pitch display right click to reset to 0
geposted Sat 25 Nov 06 @ 12:26 am
Hi dj FOrmat!
Maybe i'm doing wrong, but it's not working for me.
EXAMPLE:
DECK A)
01:25.0 02:58.0 +0.0% 130.0
DECK B)
00:00.0 03:49.0 +0.0% 127.1
I want to to DECK B Have the BPM of DECK A
i do that you say,
"clicking on the the pitch display right click to reset to 0"
If i click Rigth "+0.0%" on DECK B, it Apear like:
00:00.0 03:49.0 +2.3% 130.0
Rigth! perfect (Now i have the two song with the same BPM)
and now i want that the DECK B, star palying, but in the SYNCRONITATION. In the others skins, i pres the SYNC buton,but, that s not working at the moment in any panels of this SKIN.
MAybe now, i xpress better than before.
Also, there is a desk panel into the skin,it's the last panel of the desck were apear SYNC button and it's not working
I`m doing correct? No one have this problem with the SYNC button?
Thanks for your help!
CHerss
Note: SOrry for my english!
SALUD
Cherss
EXAMPLE:
DECK A)
DECK B)
i do that you say,
CHerss
SALUD
Cherss
geposted Sat 25 Nov 06 @ 1:26 am
I try to edit the other post!
I was trying more with the skin, and i look the option that i'm speaking!
In the last two panels of the decks, apear the SYNC button:
If i press rigth the SYNC button, it modificate the BPM
But if i press LEFT the Sync button, it star playing syncronizated! this is the function that i was looking for!
Now that i see were is that. this function (SYNC) not apear in the other panels no?
It's possible to add this option in the time panel, for example clicking left the Play time?
Thanks a lot for all the help!
Cherss!
Dj Pillo
Cherss!
Dj Pillo
geposted Sat 25 Nov 06 @ 1:50 am
That is ok M8
geposted Sat 25 Nov 06 @ 2:07 am
You are looking for a sync start button, let me see what I can come up with. Vmix4 is ending in development very soon to make way for the next version of vmix number 5. Just like all previous versions of vmix it will be unique and ground breaking ;)
geposted Sat 25 Nov 06 @ 4:17 am
favoluse! i'm going to wait nervouse...uhmmm more sweets...V5!
good new.
cherss to much
Salud
Dj Pillo
good new.
cherss to much
Salud
Dj Pillo
geposted Sat 25 Nov 06 @ 3:49 pm
