ive had vdj and the hercules dj console for a while now & everything was fine..
had to put another hard drive in my computer & reload everything .....
now when i use vdj and a song is playing i cant speed up the song or slow it down a little to cath up the beat with the jog wheels because if i try to move the wheel just a little forward it speeds up the song so much that it sounds like i put the pitch adj as fast as it can go and if it is too much ahead and i want to slow the song down a little if i just move the wheel backward a little it sounds like i am almost stopping the song........
i have reloaded everything 3 times... and have NEVER messed with any of the setteings to vdj or to the dj console... any ideas of what is going on
i used to be able to move the wheel forward a little & catch up without hardly noticing, now when i go forward it sounds like the chipmunks are singing.......
your help would be appreciated.........thanks
geposted Wed 25 Oct 06 @ 5:03 am
Have you checked the settings for you console in the config screen? Check on the controller tab in the Hercules box "Use jogs to scratch"
Ewout
Ewout
geposted Wed 25 Oct 06 @ 6:52 pm
