Which is the proper way to add karaoke files? I end up with duplicate entry´s. VDJ lists booth the mp3 and cdg part... Most other software takes these files from within a zip archive i think.
geposted Wed 25 Oct 06 @ 7:02 pm
yep you can zip them and add zip to your extensions in the codecs tab
geposted Wed 25 Oct 06 @ 7:05 pm
Jepp, it works but not ok.
Possible bug here....
I cant have files like
"CK051-01 - Grease - Beauty School Dropout.mp3"
"CK051-01 - Grease - Beauty School Dropout.cdg" in zip, they generates Error in player, but if I rename them to
"Grease - Beauty School Dropout.mp3"
"Grease - Beauty School Dropout.cdg"
then its ok
then its ok
geposted Wed 25 Oct 06 @ 10:45 pm
If you need to re-name them may I suggest Dr tag. It is a great program that also renames the CDGs when you re-name the MP3s. Then simply zip them up, add ZIP to your codecs for karaoke and you should be good to go.
geposted Thu 26 Oct 06 @ 3:34 am
Do you need to zip each mp3/cdg file separately?
geposted Thu 26 Oct 06 @ 4:16 pm
