I see in many pictures people have mk2 2 turntables and a computer
well I have that same thing,
-Laptop with virtual dj 4.0
-2 numark cdx
-numark 200fx mixer
-hercules mk2
the reason I bought the numarks is because I want to scratch and play the songs from the computer, but I noticed when i chaged it to the turntable mode, it went straight to the cd which I don't want.
Is it possible to scratch and play songs from the computer through the numark cdx?
-2 numark cdx
-numark 200fx mixer
-hercules mk2
geposted Thu 26 Oct 06 @ 10:08 pm
is it midi enabled?
geposted Thu 26 Oct 06 @ 11:11 pm
you need to use timecode cd's to use the CDX to control VDJ
geposted Thu 26 Oct 06 @ 11:27 pm
how could i forget that i am getting old as u say norway lol
geposted Fri 27 Oct 06 @ 2:15 am
tell you what..
since you do have vdj 4, why dont you enter the serial number in your profile...
@norway...
have we given up???
cheers
DJ Rudra
@norway...
have we given up???
cheers
DJ Rudra
geposted Fri 27 Oct 06 @ 4:17 am
might be a demo ;)
geposted Fri 27 Oct 06 @ 4:18 am
step 1
download that
download timecode cd!
step 2
burn it as an audio file x2
step 3
go to sound config
software setup guide!
copy these settings
however in the timecode config menu pick timecode cd
conect it like that :) cept cd players instead of vinyl records
Hope that helps!
Skyfxl
ps if u like the software please buy it
geposted Fri 27 Oct 06 @ 4:22 am
nice drawings.. :)
however, would it be better to connect the cd players to the external mixer rather than the console..
will i still be able to use tccds??
never wanted to till now, since i have just started a collaboration with a cd dj..(poor chap, he drools all over my console..makes it wet and slippery >:[ :))lol
cheers
DJ Rudra
cheers
DJ Rudra
geposted Fri 27 Oct 06 @ 5:01 am
it depends as i dont think he has two soundcards , it would be difficult to get the signals through with only one
glad u like the pretty pictures lol :)
the tccd should be fine for u :)
geposted Fri 27 Oct 06 @ 5:04 am
you are one fine artiiiist.
geposted Fri 27 Oct 06 @ 10:31 am
thanks sadly cant say i drew it lol
found it on some estranged japanese website
gona try and make some more in the same style
geposted Fri 27 Oct 06 @ 11:43 am
My problem is that I need the someone to lower the volume on the timecode, because I see the waves go apenuts but its still at 0%, so i'm assuming from many posts i've read the volume needs to be edited with Nero wave editor. But I don't have that program and was in search of someone capable of doing me the special favor.
geposted Fri 27 Oct 06 @ 11:00 pm
Ah and can someone elaborate what the term Midi, and if its necessary? I see some midi inputs but I don't understand its use
geposted Fri 27 Oct 06 @ 11:05 pm
(Musical Instrument Digital Interface). Standard specifications that enable electronic instruments such as the synthesizer, sampler, sequencer, and drum machine from any manufacturer to communicate with one another and with computers.
and try audacity its a free wavform editor
audacity.sourceforge.net
to lower the volume
to lower the volume
geposted Fri 27 Oct 06 @ 11:26 pm
