Hey gang...
I have the M-Audio Fast Track Pro on order and would like to eventually use the time coded cd's at the club. I have heard that I may not have the right card, after being told that it would be good for VDJ.
My lappy is suppose to have a firewire port so that shouldn't be an issue.
Did I mention that I don't want to spend more than $200?
My external HD is a USB 2.0 or a firewire, so what should I use with the firewire port, if I have a choice?
I have been hearing too many issues with the gigaport and the u46dj cards.
Just trying to sort through the confusion.
Also, once I get it
Also, once I get it
geposted Fri 27 Oct 06 @ 1:48 am
Fasttrack is a great card.... works great with vdj
It just dont have regular line-ins to connect your turntables too.
So you need a card like u46dj, or similar...
Firewire card can have benefits over usb cards on laptops, yes.. because of IRQ sharing issues.
But for most, u46dj will work great
geposted Fri 27 Oct 06 @ 2:05 am
