when i first got this program i cued all my songs and if i closed the program and opened it back up the cues was at the spot i left them in, but now for some reason its not saving my cues anymore. i'll cue a song exit the program and the cues are gone. i still have my other songs cued but the new ones won't cue for some reason... what going on?????????
geposted Fri 27 Oct 06 @ 2:37 am
have u edited there tags in anyway?
geposted Fri 27 Oct 06 @ 5:01 am
by tags do you mean the name of the song?
geposted Fri 27 Oct 06 @ 12:25 pm
yes the id3 tags
and the vdj tags
and the vdj tags
geposted Fri 27 Oct 06 @ 12:28 pm
@skyfxl..
does enabling "write cdj tags" affect this situation in any way??
if it does, make sure that write tags in the options tab is checked..
cheers
DJ Rudra
cheers
DJ Rudra
geposted Fri 27 Oct 06 @ 1:39 pm
and hang on..
how about entering the serial number in your profile while you're at it..
cheers
DJ Rudra
cheers
DJ Rudra
geposted Fri 27 Oct 06 @ 1:42 pm
mate uv gota stop acusing every one of piracy lol , they might be demo users!
i belive that would help
geposted Fri 27 Oct 06 @ 1:49 pm
yeah i know..im on a rampage lol :))
geposted Fri 27 Oct 06 @ 7:19 pm
what is id3 tags and vdj tags? i'm kinda new at this. so basically you guys are saying that i need to change something in my configurations, if so then what?
geposted Mon 30 Oct 06 @ 12:19 am
i have two options in my configurations, 1. Write VDJ Tag 2. Read ID3 Tag. so what should do with them?
geposted Mon 30 Oct 06 @ 12:22 am
do u get any messages about internal database errors? ever
geposted Mon 30 Oct 06 @ 12:33 am
nope
geposted Tue 31 Oct 06 @ 1:57 am
i was looking at my configurations again and the "AutoCue" option is on always, would that have something to do with it. and what about the "Write VDJ Tag and Read ID3 Tag" what option should those be on?
Oh yea those auto cues was pretty cool i never knew about that but i'm pretty sure it wouldn't work right every time plus i want to cue every song myself and sometimes i can't find a instrumental to a song so i just loop a part of the orginal song that doesn't have any lyrics in it... i know, that sounds kinda dumb but it works
geposted Tue 31 Oct 06 @ 6:17 am
