Forum: Old versions
Topic: Numark CM200USB
Hello,
After purchasing the Behringer VMX 1000 mixer, I am definitely looking for something else, since it's sound quality is very bad.
I was looking at the Numark CM2000USB mixer which IS a 19" mixer and has build in USB sound cards.
If anyone has used it, please answer me the following questions:
Do it's build-in soundcards work OK with VirtualDJ?
Does it have asio drivers?
How is the sound quality?
Thanx in advance!
Alex
geposted Sat 28 Oct 06 @ 4:12 am
I have a cm200usb mixer and I'm pleased with it. It works verry well with vdj. It doesn't have asio driver. The quality is good (I had a behringer vmx200 mixer and I can't say there are diferences regarding the quality of sound).
