I have a friend who has a question.... can VDJ have 2 decks with two different playlists. IE: one for each deck? If not, any ideas for a program?
geposted Mon 30 Oct 06 @ 3:07 am
The only way i think it would work is to have VDJ running in multi deck mode and use whatever playlist you wanted for whatever deck. Why anyone would want this is far beyond me. The search program that VDJ has is awesome and can find a tune as quick as you can type it.
Keep the beat sweet.
geposted Mon 30 Oct 06 @ 3:17 am
Why would you want 2 playlists vdj has a playlist and a side list
geposted Mon 30 Oct 06 @ 6:39 am
which rock :)
geposted Mon 30 Oct 06 @ 11:42 am
...On the note of the side list down the bottom of the window, is there any way to load a song from there, or scroll throught that list with the DAC 3 and Boggis's mapper?
As far as I can tell, that list is just a place to put songs to quickly find them, but as mentioned above, you can find a tune as quick as you can type it. That is quicker than grabbing the mouse and dragging up from the bottom list.
geposted Mon 30 Oct 06 @ 3:42 pm
