Hi All, My first post so be gentle. I just got the Behringer this morning and all is working great apart from one thing. Any actio I want to perform requires exactly two presses of the button on the controller! Is this a setting I've missed? Or could I have a faulty unit?
Thanks all for the help, I did search but could find nobody else with this issue.
I'm using VDJ 4.1r2 and the latest BCD drivers.
Thanks
Thanks
geposted Wed 01 Nov 06 @ 8:30 pm
*Solved*
For the sake of any other user, I changed from global mode to BDJ mode in the little app that comes with the drivers.
B
B
geposted Wed 01 Nov 06 @ 9:09 pm
kool :)
geposted Wed 01 Nov 06 @ 9:24 pm
geposted Wed 01 Nov 06 @ 10:49 pm
sounds like you BDJ mode send note on when pressing the button and note off when releaseing the button. if you use the global mode the first time you press the note will go on and the second the note will go off. (hence requiring 2 presses)
i have the same setting on my digi drums and its useful if you need to turn something on and stay on until you press again (like an effect)
this is sometimes called toggle and latch i belive (mostly when reffering to footswitches)
and speaking of footswitches, how cool would this be for using as a suplemental midi controller
http://www.bluearan.co.uk/menu/index.php?id=BEHFCB1010&seeimage=YES
geposted Thu 02 Nov 06 @ 12:05 am
