Is there such a connecter that is svideo male to RBG FEMALE (or to male + coupler)? If so, where can I get it?
geposted Thu 02 Nov 06 @ 3:17 am
svideo to component the answer is yes but only for 7 pin svideo
the 4pin svideo on the older video cards doesnt have the rgb information, but for the older cards just get a dvi to component adapter (depends on what outputs you have)
geposted Thu 02 Nov 06 @ 3:55 am
my laptop (dell XPS specs maxed out) does in fact have the newer svideo configuration. would I get better quality going svideo to component or dvi to component?
geposted Thu 02 Nov 06 @ 4:05 am
Same, they both have the same RGB information so either one will be fine, and both adapters can be found on ebay
geposted Thu 02 Nov 06 @ 4:11 am
thank you thank you!
geposted Thu 02 Nov 06 @ 5:36 am
No Problem, Glad to have helped
geposted Thu 02 Nov 06 @ 5:48 am
