Hey Cy,
loving your Vmix skin,
With CPU being such an important factor in using video with VDJ can you please consider the following small update...
Within vmix, below the center screen, there are 10 radio buttons for variations to the center area.
I noticed that with ones that have a smaller CPU meter length, the color changes from green to organge to red.
I use the 4th from the right (big screen, long CPU meter above) and to me it only seeems like it is green.
Maybe I havent gotten it high, enough but it seems that I have gotten it around 70%-80% but nothing but green.
If this is the case, would it be possible to have it change colors like the smaller ones so I can be aware of too much CPU and may help with other things?
Thanks.
B
Thanks.
B
geposted Fri 03 Nov 06 @ 2:02 am
would i be right in saying this can be altered in the main skin xml file ?
geposted Fri 03 Nov 06 @ 2:54 am
same one i use its all green up until the very end about 85% mark then its red, I'll change it to something better.
geposted Fri 03 Nov 06 @ 5:08 am
