**new
Right player is playing .vob out to club. A .vob is loaded on left player (with TCCD and pioneers).
I spin the the left one back (to get it ready) or even just "pretend scratch" or move platter back and forth.
the result...
the outputted video is slightly affect (studder).
This is a sort of a continuation of the problem I (and others are having) with a video playing out and when another is loaded to the other deck, there is a slight studder on the outputted video t our audeince (both drunk and sober).
There have been many setting which have been requestd to be changed by VDJ staff to deal with this issue but all with no success.
The question.. WHAT is the relationship between the right video playing out and me spinning the left one while waiting? WHy would the video out be affected by the left deck? Because whatever it is, may also be affecting it upon load.
Can a closer look from the staff be given for this?
There is a certain situation when it doesn't do it and this may be a clue. The outputted studder doesn;t happen when I load a video and then put in another one over it.
Can we look into this deeper now, or is it just something to deal with?
Dell lappy 1710 (new)
NVideo 7900GTX
Thanks,
B
the result...
NVideo 7900GTX
Thanks,
B
geposted Fri 03 Nov 06 @ 2:24 am
has any one sugested proformance settings
if not try lowering them to fast
preferences>proformances
fast<quality
its sounds like ur cpu is being over taxxed
fast<quality
geposted Fri 03 Nov 06 @ 2:27 am
All the way to the left?
I'll try again.
tx
I'll try again.
tx
geposted Fri 03 Nov 06 @ 2:47 am
yes
that should solve it then you can move it back towards quality bit by bit to find the best setting
geposted Fri 03 Nov 06 @ 2:49 am
@sky,
when you say bit by bit, in my performance slider, I can only move it in increments. There is only 4 places I can move it. Is this correct?
Fastest ticker ticker Best quality.
Can I get in the middle of these "bit by bit?"
Thanks.
Thanks.
geposted Fri 03 Nov 06 @ 3:03 am
