So if anybody knows how to set 3 buttons at XP10 controller to activate each button each effect please write. I didn't get the solution in 4 hours of trying!
Explanation:
Just like it was in v3.4 and before:
button 1 on xp10 (it doesn't matter which one) activates effect Flanger (for example)
button 2 on xp10 activates effect Cut
and button 3 on xp10 activates effect BeatGrid
Now.. how to define which effect it will activate? by names? by numbers that they are sorted? (because you can't sort them manually).
If i define effect_active action and Value 0 it just activate the effect that is momentaly selected. If i put in value 1 it does the same thing. I would like to set action to select AND activate the effect.
Anybody has any idea how to do that in v4??? I don't want to select effect and then push 1 button everytime i want to activate it.
thanks
Explanation:
thanks
geposted Mon 06 Nov 06 @ 5:44 pm
Add to previous post:
Everything would be great IF:
at action "effect_activate" i set value 0, it activate effect that is momentaly set (choosen)
then when i set value to 1 it activate effect 1 (as first top effect that is at effect list)
when i set value 2 it activate 2nd effect and so on.
Now all numbers has the same function!
I think that could be corrected if there are no other possibilities, because effect_activate is the only action that has possibility to choose and active all effects
What do you think???
geposted Mon 06 Nov 06 @ 7:07 pm
Teamers are faster than all people on forum together :D
So.. it is not possible at the moment.
To all XP10 users:
To select the exact effect, use action effect_select_multi and as value write number of effect that you see in effect list.
Then use another button to activate it as action effect_activate and value 0.
To all XP10 users:
geposted Mon 06 Nov 06 @ 7:36 pm
