I have noticed the following happen on my MK2 in conjunction with VDJ and I am wondering if others have seen it and know a way to resolve it.
When the crossfader is on the far right, all (10) lights are on. When you move it a quarter the way accorss, it is still on 10, but by the time you move it to the middle, it is on 7, and the volume dips a bit.
As a workaround it is possible to leave the crossfader in the middle and use the volume controls instead. Perhaps this is the best way to do this anyway...
geposted Tue 07 Nov 06 @ 8:21 pm
did you try to run it with power adapter?
geposted Tue 07 Nov 06 @ 10:33 pm
adjust fade lengh in settings
geposted Tue 07 Nov 06 @ 10:35 pm
setting fade length to full achieves my desired result.. cheers
geposted Wed 08 Nov 06 @ 10:22 am
good to hear :)
geposted Wed 08 Nov 06 @ 10:59 am
