I plan to buy VDJ and connect my mixer to it through USB (it has soundcards in the mixer). I know that this will work; my question is if it is possible to hook up tables to the mixer and keep the mixer connected to the computer through USB and use timecoded vinyl. If this will work, is it still possible to use the beat match option with time coded vinyl? Thank you!
geposted Wed 08 Nov 06 @ 10:10 pm
what soundcard , which mixer
please be specific as possible or its hard to help :)
geposted Wed 08 Nov 06 @ 10:58 pm
Sorry for not being specific. it is a Numark DXM01 USB mixer and it has two Conexant AMC audio cards. Thanks!
geposted Thu 09 Nov 06 @ 12:00 am
sorry, forget the audio cards I told you, that was a mistake. When trying to select the audio cards on VDJ's configuration, they are called "USB Audio CODEC." I looked hard for any mention of what the exact name of the sound cards in the mixer are called but I could not find any mention, even in the manual.
geposted Thu 09 Nov 06 @ 12:13 am
select a dual soundcard setup on the sound card config :)
geposted Thu 09 Nov 06 @ 11:34 am
select the two usb cards as the two cards
then all should work
if not please post a screenshot of your sound config using www.tinypic.com
here
here
geposted Thu 09 Nov 06 @ 11:37 am
can you select 2 usb cards ? or just one?
cheers
cheers
geposted Tue 14 Nov 06 @ 6:29 am
