how to intall upgrade ?? keep getting a message "need vdj installed first" which is intalled?
On my other computer I have both v3.4 and v4 and cannot install upgrade either getting message" you need correct version of VDJ for upgrade? how do I apply this exe upgrade file to v4.o?
many Thanks
many Thanks
geposted Thu 09 Nov 06 @ 7:49 pm
rename the 4.0 to virtualdj.exe and the 3.4 to virtualdj2.exe
geposted Thu 09 Nov 06 @ 8:41 pm
My computer crashed on me last night - I had to do a full factory reset. Unfortunately, I've had to go "back to basics" with my Virtual DJ, as it has decided it can't read CD ROMs I haven't bought any more. Fortunately, it retained most of my music files.
geposted Fri 10 Nov 06 @ 3:42 pm
possibly cd rom failure?
geposted Fri 10 Nov 06 @ 3:50 pm
Maybe - it has no problems with CDs and CD ROMs I've actually bought - but it seems to have developed an aversion to anything I've downloaded off the net.
Just bought an external hard drive from Currys - only ordered it today.
geposted Mon 13 Nov 06 @ 11:17 am
gluck :)
geposted Mon 13 Nov 06 @ 11:38 am
not sure why it wouldnt of upgraded :S
i would maybe uninstall v3.4 first ( as maybe upgrade is confused which files to upgrade as there are two sets )
I wouldnt of thought it was a cd-rom problem, you would get a "Read/Write Error" box if it was ( like i get when i burn cd/s dvd's :( )
hope this helps
hope this helps
geposted Mon 13 Nov 06 @ 6:35 pm
I had accidentally deleted my sound driver instead of an image file, so I had to do a factory reset to get the driver back. Unfortunately, I couldn't get the CD of any version after the version I bought to even load up - the drive says the disc is empty (says there's no files on it) - but, when I check the "empty-full" ratio, it says it's full - in total contradiction of the apparent facts. It's both full and blank at the same time, which is scientifically impossible.
geposted Tue 14 Nov 06 @ 3:52 pm
