quick question how do you make the virtual dj public via shoutcast?
so it shows on the www.shoutcast.com dir every time i use it , i drop from shoutcast.
there must be a way of making the virtual dj To set it boardcast to public?
any help would be great.
with thanks
geposted Fri 10 Nov 06 @ 3:17 pm
1. buy the software
http://www.virtualdj.com/purchase/
2. add these server settings
host : 205.188.234.120 port 80 or 8000
3. add a name for your stream :)
geposted Fri 10 Nov 06 @ 3:25 pm
or
put the shoutcast server component on your machine if this doesnt work
http://www.shoutcast.com/download/serve.phtml
and in the host box
on vdj type Localhost
and in the host box
geposted Fri 10 Nov 06 @ 3:26 pm
thanks just saw that post.
yes thats for local hosting. on your pc. my hosting is on webserver out in cyberspace.
is it the same proccess
geposted Sat 11 Nov 06 @ 8:03 pm
if your using shoutcast you need to have a shoutcast server running on your pc....
or some one to point it to the shoutcast directory server for u
geposted Sat 11 Nov 06 @ 8:35 pm
