I am about to purchase this notebook just wondering if it will meet mim standards to do video mixing with virtual dj.
thanks for your help in advance. sale ends today.
Model Number
Aspire 3680
Operating System
Microsoft Windows XP Home Edition (Service Pack 2)
Motherboard Chipset
Mobile Intel® 940GML Express Chipset
Processor
Intel® Celeron® M Processor 410
Processor Speed
1.46GHz
Level 2 Cache
1MB Level 2 Cache
Data Bus Speed
533MHz Frontside Bus
RAM Installed / Max RAM Supported
512MB PC-4200 DDR2 RAM (Expandable to 2.0GB)
Memory Configuration
(2) 256MB SO-DIMM Memory Modules
Memory Slots Available
(0) Available 200-pin SO-DIMM Slots
Hard Drive
60GB ATA/100 hard drive
Multimedia Drive
Combo 8x DVD-ROM / 24x24x24 CD-RW Drive
Display Type
14.1" Widescreen XGA Display
Video Card
Intel® Graphics Media Accelerator 950 Video Chipset
Video Memory Installed
Up to 224MB of Shared Memory
Internal Max Resolution
1280 x 800 at 24-bit (16.7M colors)
Sound Card
Intel® High Definition Audio Chipset
Sound Output Mode
Stereo Sound Output
Modem/Communications Device
56K V.92 Fax/Modem
Data/Fax Transfer Rate
56Kbps Data / 14.4Kbps Fax
Network Features
10/100 Fast Ethernet Network Adapter
Wireless Network Features
Built-In 54Mbps 802.11b/g Wireless Network Adapter
Ports and Connectors
(3) USB 2.0 Ports, (1) VGA 15-pin Port, (1) TV out S-Video Port, (1) Headphones/speaker/line-out jack with S/PDIF support, (1) Microphone-in Jack, (1) Audio Line-in jack, (1) RJ-45 Ethernet Port, (1) RJ-11 Modem Port
Model Number
Aspire 3680
Operating System
Motherboard Chipset
Processor
Processor Speed
1.46GHz
Level 2 Cache
1MB Level 2 Cache
Data Bus Speed
Hard Drive
Multimedia Drive
Display Type
Video Card
Sound Card
Sound Output Mode
Stereo Sound Output
56K V.92 Fax/Modem
Network Features
geposted Fri 10 Nov 06 @ 7:21 pm
Short answer is NO
Intel Graphics will not support Hardware accel. Sorry
geposted Fri 10 Nov 06 @ 7:51 pm
but if its for audio only its ok
just no video
just no video
geposted Fri 10 Nov 06 @ 7:54 pm
Darn.......it was only $399.00 at microcenter here in houston.
geposted Fri 10 Nov 06 @ 8:07 pm
It should work just fine, as long as you are not doing video. specs are pretty decent. Running Audio doesn't require much of the video card, but video will. Hence, the specs are just fine, up until you get to the video requirements.
geposted Fri 10 Nov 06 @ 9:10 pm
geposted Fri 10 Nov 06 @ 10:50 pm
My LAPTOP is just about the same specs as yours... it's totally fine... never had a problem with it.
geposted Sat 11 Nov 06 @ 12:40 am
The beggining of his message cleary ask if it meets the min req. for mixing video. so lets keep the answer at No,so that no one gets confused, Im not saying it can't do it...but without the hardware accel you will find that alot of the video effects won't work..also not having it enabled will tax your cpu and give you numerous freezes of video while playing.
geposted Sat 11 Nov 06 @ 3:33 pm
Thanks for your help I decided to upgrade my desktop and bought a Nvidia Geforce 7600 gs oc graphic card. agp 8x/4x 512mb ddr2. I hope this will work. Now I have to upgrade to the full version of virtual dj. All I want to do is mix music videos with virtual dj. I am new to virtual dj and I must say I like it. I am a traktor user and have been since version 1.0. I do all my gigs (club, weddings...etc) with a laptop running traktor. So I am excited to add virtual dj into the mix. (more money for me)!
geposted Sat 11 Nov 06 @ 6:13 pm
