Forum: Old versions
Topic: little Cue point question...
Does anyone know some common reasons why if you put a cue point (marker) in a song and go back to it the next day, that the cue marker may not be there any longer? Happens on a few songs.
Sometimes I go back and it's there, other times it is not.
Just looking for reasons for this. There have been no unusual changes between times that I see it.
Thanks.
B
geposted Sat 11 Nov 06 @ 5:33 pm
Did anything change the file for the track? Like using a ID3 Editor and adding data to the tags?
VirtualDJ tracks each track by filename, size and tagdate - example
<Song FileName="Beyonce feat Jay Z -Upgrade.mp3" FileSize="6553959" TagDate="611091928">
So if the file changes by another application other than VirtualDJ then you experience will happen. By the Way - it could be as simple as playing the track in iTunes or other player and that application writes data back to the ID3 tags.
cstoll
