im considering buying the u46dj but where's the intrustions on how hook it up
Is there any other soundcard like the maya44?
can you use any mixer with the u46dj because i have a gemini pmx 500
geposted Sun 12 Nov 06 @ 1:38 pm
yes you can if you do a search you will find details instructions but basicaly
you put the inputs from your decks
into two seprate channels like on the maya 44
geposted Sun 12 Nov 06 @ 1:43 pm
though a copy of virtual dj might help too. trial is very limited to what you can do :)
I own the u46dj, dont get me wrong is a good card, but i prefer my M-Audio Delta44. You gonna use laptop or desktop
geposted Sun 12 Nov 06 @ 4:18 pm
i will be using my laptop no problem i will buy just wanna see if this is a better buy than serato cause i have it
geposted Wed 15 Nov 06 @ 12:08 am
