whats up, i need help on how to broadcast any advice
geposted Mon 13 Nov 06 @ 2:13 am
hi!
if u want to broadcast click on the recording tab than broadcast than config if u want to broadcast to radio server than fill in the server ip and the password than click ok than start recording.
if u want to broadcast from your own computer than select broadcast from my own computer than ok than start recording.
make sure to buy pro works better cuz i tried with trial didnt work as good. so if u can buy pro! i hope that helps!
geposted Mon 13 Nov 06 @ 2:57 am
purchasing a full version is good advice for broadcasting. You can only broadcast for the extent of the trial.
geposted Mon 13 Nov 06 @ 7:53 am
