hi all .i just started using a mixer with virtual dj and i have 2 problems.
first one channel sounds louder than other.i use 2 sound cards.for now i adjust the volume of one to match the other but i cant get it to do so exactly.
second when i have a song playing on channel 1 and i bring up channel 2 to mix together.channel 2 doesnt sound as strong. but when i lower the volume on channel one .channel 2 gets louder. can anyone help i tryed 2 mixers .the one i want to use is a beheringer vmx200.and i even tryed my old gemini simple mixer. is there something i need to configure to make both sides sound even and never change.
thank you
thank you
geposted Mon 13 Nov 06 @ 2:25 pm
which soundcards are you using :)?
geposted Mon 13 Nov 06 @ 3:13 pm
i am using the one that came with the computer the other one is diamond- extreme sound 7.1/ 24 bit thats the one that lower than the one origional on the computer.
geposted Mon 13 Nov 06 @ 3:15 pm
thats a tough one
you could set them both low and compensate on the mixer?
geposted Mon 13 Nov 06 @ 10:18 pm
