When i ripp promo dvds with the new dell, i use smartripper. then i convert the file by changing the file extention to .mpg. though, it keeps it in vob format. I plug the hdd into my desktop pc and the file name looks like this Madonna - Jump.mpg.vob
does this sound familiar?
geposted Mon 13 Nov 06 @ 11:46 pm
You need to go to windows explorer then select "tools" and "folder options", in "view" disable "hide file extensions for known files".
geposted Tue 14 Nov 06 @ 4:08 am
ahhh, thank you. ill try that when I get home and hopefully that will solve this little annoyance of mine!
geposted Tue 14 Nov 06 @ 3:59 pm
Once you do that you won't see the 2 extensions, you'll only see that one that you have renamed :)
geposted Tue 14 Nov 06 @ 5:38 pm
perfect, it worked well. now, im wondering how I can play these files in winamp. Im using the latest version of winamp and I use the milkdrop plugin for video
geposted Tue 14 Nov 06 @ 7:51 pm
Select the file then mouse right click and "open with" "chose program" and search for winamp.
BTW: if you want that all that kind of files are open with winamp just tick "Use the selected program for opening these kind of files" :)
geposted Wed 15 Nov 06 @ 5:55 pm
thank you, all is gravy!
geposted Wed 15 Nov 06 @ 9:24 pm
Glad to help you :)
geposted Thu 16 Nov 06 @ 5:54 pm
