Tried so many options, however, popping clicking noise rightside player in v4+ regadless of switching sound cards and setup. Clicks every other beat, i updated all drivers tested on 2 different computers (1gb ram intel 4w/HT 3.2 ghz) and still clicks on right side. same sound card saurce works on left fine but if switched to the right player popping and clicking starts.
I love VDJ software, we use it in our club but popping&clicking in v4.1 right player has been a nightmare.
Please help.
many Thanks
Shaath
Please help.
many Thanks
Shaath
geposted Wed 15 Nov 06 @ 7:47 pm
Could be an IRQ sharing conflict with video maybe.
geposted Thu 16 Nov 06 @ 12:38 am
I to am having the same problem. Its only on the right deck. all the other software I have used doesn't have that problem.
Soundcards are 1: Creative Labs
2: C-Media
I have tried everything I found on the forum, and I have no irq conflicts.
2: C-Media
geposted Sat 20 Jan 07 @ 11:39 pm
If you are using 2 sound cards and you have not updated to 4.2r1 then you should.
If you have updated to 4.2r1 then make sure you have updated your DirectX as well.
http://www.microsoft.com/downloads/details.aspx?FamilyId=77BC0499-19D0-46B6-A178-033D9E6C626B&displaylang=en
geposted Sun 21 Jan 07 @ 12:00 am
i've tried that with no results i think it is a problem with the program. vdj 3.4 is best by far a more flawless program.i know when step up to the big league you got to bring something to the table but all of the tech work makes it non- user friendly. so now i'm waiting on version 4.3 and please consider correcting the two soundcard issue
geposted Wed 28 Feb 07 @ 9:04 pm
Update your DirectX --
http://www.microsoft.com/downloads/details.aspx?FamilyId=4B1F5D0C-5E44-4864-93CD-464EF59DA050&displaylang=en
and do not use the Safe Mode + Enhanced Algorithm in the SCRATCH section of the Performance Tab. If you are going to use the SAFE MODE for a laptop then use the Simple Algorithm, and the opposite if you need to use the Enhanced Algorithm then uncheck the Safe Mode.
geposted Thu 01 Mar 07 @ 7:47 am
mojo193 said " Posted Wed 28 Feb 07 @ 15:04:24
i've tried that with no results i think it is a problem with the program. vdj 3.4 is best by far a more flawless program.i know when step up to the big league you got to bring something to the table but all of the tech work makes it non- user friendly. so now i'm waiting on version 4.3 and please consider correcting the two soundcard issue.
Need I say more. I think a 5.0 ver is required.
geposted Thu 01 Mar 07 @ 2:38 pm
Like Cstoll just said update your Direct X as there is a Feb update.
geposted Thu 01 Mar 07 @ 11:51 pm
having same issue...wonder if USB speed might be an issue...only deck b clicks though
bill
bill
geposted Thu 08 Mar 07 @ 5:54 am
