I BURNED A FEW CDS TO MP3 THEY WILL PLAY IN ITUNES BUT NOT IN ATOMIX WHAT COULD POSSIBLY BE THE PROBLEM?
ALSO UNDER THEIR PROPERTIES THEY ARE SHOWING THEY ARE MP3 FILES
THANX IN ADVANCE
W
THANX IN ADVANCE
W
geposted Thu 16 Nov 06 @ 7:25 pm
itunes files will not play in any other aplications sorry
as itunes have banned the use of their drm
geposted Thu 16 Nov 06 @ 7:44 pm
I dont use itunes, but maybe there is an option to burn them to a different file format? Only if they were not DRM to begin with i guess...
geposted Thu 16 Nov 06 @ 8:11 pm
aslong as you dont use intunes to rip them
yes
yes
geposted Thu 16 Nov 06 @ 10:40 pm
I APOLOGIZE I USED ROXIO'S AUDIO CENTRAL TO RIP THEM -I WAS JUST WONDERING WHY IT WOULD PLAY IN ITUNES & NOT ATOMIX - THANK YOU SO MUCH FOR YOUR ADVICE ITS MY FIRST TIME USING A FORUM
geposted Fri 17 Nov 06 @ 2:22 am
Please disable you Caps Lock
geposted Fri 17 Nov 06 @ 2:43 am
OK..................
geposted Fri 17 Nov 06 @ 7:22 pm
yes u can..
please stick to atomix products on an atomix forum lol
geposted Fri 17 Nov 06 @ 7:23 pm
