Hi i was wondering, as a proud Home Editiion user?
Would I Be able to broadcast with it?
Cheers
Cheers
geposted Fri 17 Nov 06 @ 3:23 pm
Please try not to Double Post
geposted Fri 17 Nov 06 @ 3:40 pm
where did i double post?
geposted Fri 17 Nov 06 @ 3:43 pm
Diffrent Topic Name , same question
https://virtualdj.com/forums/60001/General_Discussion/Can_I_Broadcast__anyway_.html
geposted Fri 17 Nov 06 @ 3:59 pm
check your recording tab if there is broadcasting the answer is yes lol
geposted Fri 17 Nov 06 @ 4:14 pm
but how can i get the plugin to broadcast?
geposted Mon 20 Nov 06 @ 1:01 pm
if its not in the recording tab its not supported sorry
u need pro
u need pro
geposted Mon 20 Nov 06 @ 1:14 pm
i got the broadcasting tab in the recording tab, but im missing the Plugin to use to BROADCAST, any hints/sites on where i can find that plugin? i just need the plugin
geposted Mon 20 Nov 06 @ 2:06 pm
u cant fin it cuz u need pro.
its called laminc.dll
and u need pro to use broadcast
please buy it if u like it.
im a proud vdj user!!!!
wes smith
wes smith
geposted Mon 20 Nov 06 @ 11:22 pm
howdy
news for u
u can
but u need shoucast source files
if u download this
http://www.shoutcast.com/downloads/shoutcast-dsp-1-9-0-windows.exe
and install it
now point the broadcast section to the main shoutcast dsp .dll where you installed it
install the shoutcast server components
http://www.shoutcast.com/download/serve.phtml
and use vdj like you would winamp
and u can broadcast if u want to skip all this
buy pro ;)
with pro all built in and vdj can aslo be a server
news for u
u can
if u download this
and install it
buy pro ;)
geposted Mon 20 Nov 06 @ 11:40 pm
