Do you recommend any?
Thanks
Thanks
geposted Fri 17 Nov 06 @ 6:10 pm
Enntec Lightfactory, but you have to get the full 512 ch or 1024 channel version, can't wait to see if VDJ's DMX interface is upgraded
geposted Fri 17 Nov 06 @ 8:12 pm
I can't see anybody ever needing all 512 channels honestly unless its in a club.
10 lights at 6 channels each is only 60 total if you know what I mean.
Most lights run 4-6 average, even 256 channels is going to work fine.
I recently tried Freestyler http://users.pandora.be/freestylerdmx/ which is free/donation ware.
Couple that up with this dongle and your in for short money.
http://cgi.ebay.com/Enttec-Open-DMX-USB-Interface-PC-Based-512CH-70303_W0QQitemZ170051074506QQihZ007QQcategoryZ29942QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
geposted Fri 17 Nov 06 @ 8:35 pm
www.dmxcontrol.de - freeware
geposted Fri 17 Nov 06 @ 10:02 pm
Some others:
- Sunlite
- Martin lightjockey
- Innovate show control
I prefer Sunlite and freestyler at this moment.
See also this and this post about integration of dmx software in vdj.
@mp3rick, I use moving heads, with 16 channels each, so 8 will use 128 dmx channels, which is already 1/4 of 1 dmx universe. I also use 16 dmx led pars (5 channels each) is also 80 channels. Then some other dimmers, strobo, foggers etc, So my dmx universe is almost full. Already used a dmx led wall once, this used 16 dmx universes (16*512 channels).
I like the new Sunlite dmx boxes. Those have 1 universe in and 1 universe out. You could switch the input dmx to another output universe, so you have 2 dmx outputs. These boxes could also operate without pc using the internal memory.
Ewout
- Sunlite
Ewout
geposted Sat 18 Nov 06 @ 2:19 pm
In this vein, could anyone recommend any DMX controllers for the PC? It appears that they aren't cheap...
geposted Sun 19 Nov 06 @ 10:11 pm
Hi, take a look at this website: www.madrix.de
The guys are programming a lighting controller software interface like dj'ing with VDJ. The software is available for windows. MADRIX supports a lot of dmx interfaces. I have seen that they have a audio analyzer inside. So your VDJ music will be analyzed by MADRIX. The result is a snchron light to your music! AMAZING...
geposted Tue 23 Jan 07 @ 10:15 pm
New Freestyler DMX 3.0 is out :-) http://www.freestylerdmx.be
geposted Mon 27 Oct 08 @ 10:21 am
American DJ has some new DMX software. Have not tried it yet. Sounds promising.
http://www.americandj.com/ProductDetails.aspx?ItemNumber=1773&Category=DMXSoftware&txtSearch=software
geposted Tue 28 Oct 08 @ 11:31 pm
