Topic: Cueing Videos & Karoke Files on Numarks Cue
I know how to do Audio. How to do Videos & Karaoke Files without the people from seeing them on the TV or Projector untill they are played?
Thanks Again
geposted Sat 18 Nov 06 @ 6:52 pm
only the active deck is seen on the screen if you cue or view the non active the audience cannot see it
There are different crossfaders for video and audio. If you cue up audio and your crossfader is in the center you audience will hear it, so you normally should set the crossfader to the active, playing deck. The same could be set for the video crossfader.
You could link both faders: vdj config menu->Video tab->Linked crossfader. So if you move the audio crossfader to deck 1 the video crossfader will move accordingly. You could also set keyboard shortcuts for both crossfaders.
Ewout
I use a External Mixer.
Thanks
Ok, so the concept is the same - except that the video crossfader is the only one you will have to move. Unfortunately unless you are using a MIDI controller (X-session, NUO4, etc. ) you will have to move the video crossfader by using the mouse. Now, one nice feature of VDJ/CUE is the AUTO-Crossfade (Transition) for the videos. If you want to read about the feature you can find it on pages 30 and 31 of the User's Guide
https://virtualdj.com/support/VirtualDJ%204%20-%20User%20Guide.pdf
