Anybody else using the skin authored by MiToNiOeS?? The one that emulates the Pioneer cdj100's?? Where is the configuration menu located to change it back to the default when want to?? I can't seem to find it anywhere on the skin itself...is there a way to apply the default skin while not actually in the program?? Thanks......DISREGARD!!....I found it-sorry to clog up the boards..my bad.
geposted Sat 18 Nov 06 @ 8:09 pm
try all the tabs
geposted Sat 18 Nov 06 @ 8:17 pm
remove "the skin authored by MiToNiOeS" from your skin-map.
restart vdj and there is the default skin.
geposted Wed 22 Nov 06 @ 8:49 am
